JB Systems LED Flower DMX and LED Diamond
iomedia
Real Name: Roman
I am looking for fixture files for
JB SYSTEMS Flower DMX
Here is the Link to the manual:
http://www.notape.net/files/eqs4/4164/4164-b0507bf.pdf
and
JB Systems LED Diamond
https://jb-systems.eu/led-diamond
Can someone please make these for me?
Thank you very much in advance!
Regards
Roman
Off topic: notape.net is an eshop 5 km from my home :)
iomedia
Real Name: Roman
...but they have that pdf, and I could not find it elsewhere :-)
MontyZuma
Real Name: Klaus Muth
Hi
Try this one. The manual isn't very specific about the Pattern/Chaser Number in 4 channel mode so I assumed DMX Value = Pattern Number - so no function for 26-255. Just a wild guess.
There are no physical dimensions in the manual - you have to add them in the mode definitons yourself - after getting them. Just use the fixture editor, it's self explaining.
Due to these circumstances the attached qxf must be seen as a starting point. Try it and report back.
Klaus
JB-Systems-LEDFlower.qxf
(2.78 KiB) Downloaded 84 times
MontyZuma
The Diamond docs have been a little bit better. You still have to try and to report back :). At least the physical dimensions had been included.
Klaus
JB-Systems-LED-Diamond.qxf
(3.24 KiB) Downloaded 62 times
iomedia
Real Name: Roman
Thank you very much!
I will try it out and report back.
Regards iomedia
