Jb Lighting VaryLed 384
Baer
Real Name: Matthias
Would be really great if someone can provide a definition file for the
boxy
Real Name: Robert Box
I've done this fixture (almost...).
What I can't guess is RGB colour values for the colour macros (channel 8).
If you can supply the RGB values for peacock blue, lavender tint (for example), as JB Lighting perceive them to be, I will add the colours.
boxy
Also, I cannot find the pan and tilt or photometric data for these fixtures anywhere.
JB-Lighting-VaryLED-384.qxf
(11.68 KiB) Downloaded 87 times
Baer
Real Name: Matthias
Thank you for providing the current version of your fixture definition, it really helps me ;)
Found a Fixture definition for (i think) an MA console here:
http://www.ma-share.net/forum/read.php?1,31,986#msg-986
contaning RGB colors for the macros, so maybe this helps:
JB LIGHTING@VARYLED 3 84 SMODE(1147966322).TXT
(7.73 KiB) Downloaded 77 times
What do you need exactly for PAN/TILT and Photometric data?
Sorry for my stupid questions, but have never done any fixture definitons for QLC+ :(
boxy
Perfect, I'm on it! :D
boxy
I've added the colours, please check them as there are some interesting RGB values: Magenta is listed as 255, 0, 0 (red in my book...)
(12.18 KiB) Downloaded 69 times
Baer
Real Name: Matthias
Great Thank you
will test it as soon as i have acces to the fixtures again
Any results on testing?
In addition to that, the pan/tilt max degrees are missing. They are needed before integrating the fixture in QLC+.
Baer
Real Name: Matthias
Fixture definition works great.
Some of the colors shown in QLC+ are not exactly what you get (but similar) so you need to rely more on name than picture (or simply use the RGB channels)
Could you try to find the matching colors and integrate them in the definition?
In addition to that, it would be great to have the pan/tilt max degrees - maybe you could try to figure them out?
Baer
Real Name: Matthias
Having this setup sometimes available within the next two month
Hope i have enough time to figure something out
Baer
Real Name: Matthias
Got the Pan/Tilt Angles for this fixture
Pan 430° and Tilt 270°
Unfortunatly a had no time to check out the RGB values, but i will keep this in mind.
Added Pan/Tilt values. RGB values still need reviewing.
(12.19 KiB) Downloaded 66 times
