Hi guys just wondering if anyone has a fixture profile for the Studio Colour 575 wash moving head lights, new to Q light, managed to get them running manually on the simple desk mode but apparently it's easier of the fixtures are programmed in.
Hi and welcome!
I've moved your question to better place and adjusted title.
It will help if you give us link to pdf manual of the light where the DMX values are described.
Yes we can google it, but 1) you want to make it for the fixture creator as easy as possible 2) if there are more versions of the document, only you know which one matches your light.
By the way: fixture creation is quite easy: There's an app for it, called Fixture Definition Editor installed along with QLC+.
Some description you will find here: http://www.qlcplus.org/docs/fixturedefi ... ditor.html
Tutorial is here: https://www.youtube.com/watch?v=D3omuD6F9RI
Finally some guidelines are here: viewtopic.php?f=3&t=9204 and here viewtopic.php?f=3&t=6667
- Real Name: JOSHUA
That's great thanks for that!
- Real Name: JOSHUA
This is the sheet of all the dmx channels if that's any help...
https://www2.highend.com/support/automa ... xchart.asp
