Lixada DMX-512 Mini Moving Head Light RGBW 9/11 channel
Jstein69
Hi. Here are all of the specs to help identity the unit bc no model/serial number is listed. Help with the fixture definition will be greatly appreciated if anyone has it. I cannot find a copy of the user manual so I'm not asking for anyone to create the definition. Just hoping someone has it. Thanks!!!
https://www.amazon.com/Lixada-DMX-512-A ... entries*=0
9/11 channel.
Control mode: DMX512, master/slave, stand-alone strobe, automatic
Voltage: AC 100-240V/50-60Hz
LED quantity: 1 * 10W
Power: 25W
Color: RGBW
Pan/tilt: 540°/ 180°
Electronic dimming: 0-100%
Plug type: US / EU / AU/ UK (optional )
Shell material: plastic
Lifetime: 100,000 hours
Cable length: 125cm / 4.10ft
Product size: approx. 14.5 * 17 * 23.5cm / 5.7 * 6.69 * 9.25in ( L * W * H )
Product weight: 2670g / 5.88lb
Package size: 28 * 26 * 21cm / 11.02 * 10.23 * 8.26in ( L * W * H )
Package weight: 3188g / 7.03lb
cit
Real Name: Andrea Ugolini
Hi
Have you tried writing to the manufacturer?
Contact Info
Website: http://www.tomtop.com/
Support Phone: 800-646-4280
Support Email: sales11@tomtop.us
http://www.tomtop.com/lixada-dmx512-min ... 686au.html
yokosuna
Well I own four of them ... please be a little patient and I´ll post a def. file soon
caczuchra
Real Name: Chris Czuchra
Yokosuna have you had any luck?
Patfrwar
Real Name: Patrick
hello
to help you we need a scan of the documentation that be include in the box of your moving head
looking with google i find this :
https://community.etcconnect.com/cfs-fi ... Scan-3.pdf
is it the same channel dmx ? and on your documentation do you have the information about colours and gobos ?
rgarza
Real Name: Ramiro Garza
Here's a link to a scan of the full manual
https://community.etcconnect.com/cfs-fi ... anual-.pdf
I just got a pair of these and would also appreciate it if you could help us out with the definition :)
Kind regards,
Ramiro G
Freasy
Real Name: Jan F
I created the file according to the linked manual. I am curious though, if it is really the same fixture. Specifications match but in the description it says RGBW LED, in the manual it says color wheel with seven diachronic filters...
Also the manual is funny to read ("When the color wheel of running, the light turn off"). But also some mistakes in the manual...
I am not sure about the Gobo channel. The manual says two times "Gobo Wheel run from slow to fast", while the Color Wheel has run from fast to slow and slow to fast. Please check, if the Gobo Wheel behaves like the Color Wheel.
And what is a tacitly approve dimmer? :lol:
Lixada-Mini-Gobo-Moving-Head-Light.qxf
(5.33 KiB) Downloaded 1883 times
boxy
Real Name: Robert Box
If the manual is so badly written, it's makes you wonder about the safety of the electronics.
This looks like a Chinglish American DJ copy from Shenzen or Guangzhou.
So it's a 10W white LED fixture? What filter/gobo values give which colours/patterns?
rgarza
I am expecting to receive these fixtures today and I will scan the manual an upload it as soon as I do to make sure it is the right one.
Regards,
Ramiro G.
rgarza
Thank you for creating the file Freasy. I compared the manual included with the fixtures to the one in the link and it is exactly the same one.
Kind Regards,
Ramiro G.
romandesign
Real Name: Roman
I loaded this profile in the fixture editor, but gogo pictures are missing. It looks for files in /gobos/lixada/gobo1.png etc. - where can I download those?
romandesign wrote: Thu Nov 28, 2019 6:12 pm I loaded this profile in the fixture editor, but gogo pictures are missing. It looks for files in /gobos/lixada/gobo1.png etc. - where can I download those?
That's because you downloaded the file in this thread and not the official one bundled with QLC+.
Custom gobos are not allowed, so I removed them.
https://github.com/mcallegari/qlcplus/b ... g-Head.qxf
romandesign
Real Name: Roman
But the bundled one only has numbers and verbal descriptions, while it seems possible to assign actual pictures, that's what they are there for. I'm a bit puzzled by remmebering what are the differences are of "flower1" from "flower2" and what an "impella" is. If course I can get used to it, but it's possible to have actual gobo pictures, so why not?
