Robe spot 160 xt
- titigab
- Real Name: Etienne
- pipolino419
- Real Name: Rodolfo
Here the def & manual
http://www.robe.cz/fileadmin/robe/downl ... 0%20XT.pdf
Please leave a feedback.
- Robe Spot 160 XT.qxf
- (8.67 KiB) Downloaded 175 times
- Real Name: Robert Box
Hi I've added some physical data and modified the modes:
The manual lists modes 1 and 2 as being identical (both 16-bit). Modes 3 and 4 are different (both 8-bit, 4 doesn't have pan/tilt speed).
I'm assuming mode 2 is different from 1 in the same way as 4 is different from 3. ie.: Mode 2 has only 8 channels.
Please test the above and let me know if my assumption is correct.
- (8.78 KiB) Downloaded 188 times
- Real Name: Lukas
I've removed the word "mode" to pass the fixture validator.
- (8.79 KiB) Downloaded 180 times
