What Kind of Bar Is This?
tuck
Real Name: Chris
Post by tuck » Thu Oct 19, 2017 10:28 am
Would anyone know what make this bar is? I have very little control when loading the Chauvet 4Bar or 4Bar Tri.
There are no markings on the make and model. Different kinda foot switch as well.
Thanks so much for your time.
Chris
Jungle Jim
Re: What Kind of Bar Is This?
Post by Jungle Jim » Sat Jan 13, 2018 2:37 am
I don't think it's a Chauvet 4 bar (or 4 bar tri, or mini 4 bar, or corebar), all Chauvet models have footswitches with 2 or 3 pedals.
It seems like a chinese copy of Chauvet, I found some models with similar footswitches on Aliexpress (falsely advertised as Chauvet). I could not find the maker or any manual. Your best luck if it came with a manual and DMX specifications.
https://www.aliexpress.com/item/4BAR-4- ... 54854.html
https://www.aliexpress.com/item/4BAR-4- ... 47060.html
https://www.ebay.com/itm/4-BAR-RGB-PAR- ... 1687667145
https://www.amazon.com/Ridgeyard-Christ ... B014KO991C
Good luck!
tuck
Real Name: Chris
Post by tuck » Wed Jan 17, 2018 11:13 am
Thanks For your time. Even if I had the manuals I wouldn't have a clue how to program. But I'll check out what you posted.
tuck
Real Name: Chris
Post by tuck » Fri Jan 19, 2018 7:58 pm
I wish I knew how to program this thing. I have found that it has 13 channels so I have this POS set to 13 channels addressed as 1.
So I pick different fixtures in the extended list of fixtures and get some control. So I'm making progress (some what)
Gonna keep poking at it. LOL!
Thanks for your time.
PEACE!!!
Jungle Jim
Post by Jungle Jim » Sat Jan 20, 2018 3:16 pm
If you have a manual and you can send me a picture of the page with the dmx settings, I could program it for you with the fixture manager. Otherwise you will have to find out by trial and error. You probably have one channel for each red-green-blue (possibly for each of the 4 lights), one for intensity, one of stobe effects. If you never used qlc before this might be hard to figure, but if you did use some other light you might try by trial and error in the simple desk.
tuck
Real Name: Chris
Post by tuck » Sat Jan 20, 2018 7:37 pm
I have made progress. Using your links to the fixtures, the channels they have is 13 (according to what I read) and the fixture only has 2 options 3 or 13.
3 each for RGB like you suggest for each light leaving 1 for brightness which it gives some strobe. So after picking and choosing fixture after fixture
the best one I found was Chauvet 4 bar. So for now at least I can pick colors for our next show. That beats a poke in the eye. lol
I did contact the ebay fixture seller. Of course I didn't purchase it from them so they are reluctant to give me a manual. But I havn't given up yet.
Thanks so much for your time. You've been very helpful.
More importantly I have another post out here for a new Chauvet fixture which is really cool.
I'm hoping someone would take time to do some programming. I've looked at the fixture manager but really have no clue. Is it as simple as copying
what each channel is suppose to do from the manual and putting that same info in the fixture manager?
I've come a long long way to when I first started using QLC+ due to help from this sight. THANKS SO MUCH!!
https://www.chauvetdj.com/wp-content/up ... ev4_WO.pdf
Peace Out!!
