12W RGBW EBay
DJPoppyD
Real Name: Dave Fragar
Is there already a fixture preset for these - got cheap off ebay to play around with and learn some DMX stuff
http://www.ebay.com.au/itm/322099989784 ... EBIDX%3AIT
thanks in advance
MontyZuma
Real Name: Klaus Muth
Without any documentation that's impossible to say. Since it has white LEDs, the Generic RGB won't work. But it's really not difficult to create such a simple fixture in the Fixture editor.
Since qlc+ is missing a definition for a generic RGBW fixture, I added a generic RGBW Fixture with this post. Try it. If it doesn't work for your fixture, get a PDF of the User Manual and post it (or better a link to it) here.
klaus
Generic-Generic-RGBW.qxf
(4.94 KiB) Downloaded 133 times
DJPoppyD
lights should arrive today so hopefully will be able to post the needed manual soon - can not wait to start playing with Q light
one again thanks
DJPoppyD
for what was bought as cheap off ebay they are ok value for the money for what i have seen of them so far - they are not $100 lights only $10 lights and this needs to be remembered
page 2.pdf
(825.7 KiB) Downloaded 118 times
front.pdf
(363.56 KiB) Downloaded 103 times
DJPoppyD
mlohrey
Real Name: Mark Lohrey
Give this one ago.
You might like to edit the descriptions in the colour change channels. I just put them in as per the manual but they are rather long.
Cheers
Mark
Lanling-LPR1211.qxf
(3.74 KiB) Downloaded 106 times
DJPoppyD
My DMX interface is taking its time coming but thanks for that - will let you know how I get on ASAP
steffenr
Real Name: Steffen Rose
My interface is also on the way.. hopefully.
Meanwhile I've created my own fixture as I could't find any.
The name of my LED Spot is:
Lixada DMX-512 RGBW LED Stage PAR Light
http://www.lixada.com/stage-lighting-ef ... 581au.html
but looks like yours. Maybe this works for you as well.
I would appreciate if you give me feedback anyway
lixada_15W_RGBW.qxf
(3.55 KiB) Downloaded 127 times
DJPoppyD
Great news my USB interface arrived and the show that I had had pre setup using the supplied light profile worked spot on - running the lights in 5ch mode setup - so happy that just ordered another 8 lights from the suppler to get rid of all my non LED fixtures.
DJPoppyD
uv version found here
viewtopic.php?f=3&t=11258
tzn
I have the Lixada version. For me, the strobe is not that fast at speed 255 (it is like half-speed), and the dimmers are not working at all with DMX.
Is it working for you normally?
