Audiotrigger "Exit" function
yokosuna
Hi everyone.
Problem is: when I stop the trigger widget, the chaser behind will stop at the current step, leaving the channels in an unwanted state.
How can I solve this ?
Thank you
Hey!
Maybe you could do this with the help of the loopback plugin. Trigger the "enable" button of the audio trigger widget via loopback and simultaneously you could stop the chaser and/or apply a "stop" scene.
