Double input when using Enttec Playback wing
mrcoffee
Hey everyone.
I'm trying to setup the Enttec Playback Wing, and running into an issue.
I map the "Go" and "Back" buttons to a Cue List. When you press them, a lot of the time it will count it as a double input, (i.e.: it skips one step each time.)
I've also tried mapping other buttons, and it does the same behavior.
EDIT: The double input is on the Mac version, running OSX 10.11.3. It doesn't do this behavior under a virtual Windows 7 instance on the same Mac.
Any ideas? Is it better to run the Playback Wing in ArtNet mode?
Thanks!
arretx
Real Name: Jon Griffith
Two years later and this behavior is still a problem. I'm having the same issue.
