EFX, XY PAD and position
Patfrwar
Real Name: Patrick
Hello I have a question
I have moving head fixture, il Fonction i have create EFX
in the virtual console i add an XY Pad in the Presets tab i have add my EFX
with the pan range slider and with the tilt range slider i adjuste the position of my EFX
now i want to save this parameters to use it in a button , is it possible ?
thank's for your help
and sorry for my english :)
simon9220
you could make a DMX-Dump for the Pan and Tilt channels of your controlled fixtures.
Maybe this video will help you: https://www.youtube.com/watch?v=8-bgVX4uT2E
Patfrwar
Real Name: Patrick
hello
sorry i know to save position with dump but wat i wan't to save is the size of the effect
in the screen i want to save (1) in the efx (2)
if i dump the dmx position (3) it's not realy good because the position is on the border of the circle and not at the center
i look all around qlight function and i didn't find wat i search, may be a new idea
or may be there is an other way that i did not understand
Patfrwar
Real Name: Patrick
Sorry for all
I have find the solution for my problem
I create the EFX, I create a button in the virtual console to run the EFX,
after I play RUN on the virtual console and i push the button :" Edit fonction in live mode", and i select my EFX, here, i can change all that i want at the end this was chnge in my EFX
Qlight+ is eraly greatfull :lol:
