Fade between 16 bit channels
AndreaPro88
Hello, I've tried setting up two scenes which involve a fade from a position to another, the problem is that 16 bit channels are treated as completely separate. There's a way to have a smooth transition with scenes with a lot of 16 bit channels? Thank you
