Dual or twin dmx output question
Screwy39
Real Name: Jack Jones
How do I get a dual/twin/parallel output on the same universe. I have an opendmx basic (which works with the pi but intermittently with qlc, but thats another issue) and a raspberry pi with ola.
Outputs would be either artnet and usb or two artnets or E1.31's. The pi's address is 10.0.3.14:9090.
It's to use capture Argo and output at the same time, so I can set up one wash and one mover to get the right colours compared with those on Argo screen.
Thanks again
RikSolo
You could try setting the output of the universe you want to duplicate to a loopback. Then, in two different universes set your input to that loopback and the outputs to whatever you want it. If you want to duplicate to more outputs just add more universes, set input to loopback and output to your desired output.
Screwy39
Thanks for the response. I'm away at the moment but shall try it when I get back, with the hope my opendmx will work this time.
