RGB matrix still running afte loop ends in show
hlujan
Real Name: Honza
Hi.
I have problems with RGB matrixes in Show mode. If I add some functions to show, some music, some sequences it works fine, but if i add some RGB matrix to show and loop the function until duration is reached, function is still running after reaching duration.
There are my own fixtures, but I am using only RGB channels and building show using monitor feature. I have had same problem when looping EFX.
I keep my QLC+ actual, today updated. However I had this problem in December. I use win7 pro 32 bit
thanks for help
Honza
Always updated QLC+, Win 7 - 32 bit, Mac
http://www.anacreon.cz
