RGB MAtrix addressing
Posted: Thu Mar 10, 2016 10:49 pm
by ratswallow
Is it possible to set up an RGB MAtrix with the addresses starting on the top Left and going by columns instead of rows?
For use with the Chauvet Motion Orb...they address by column instead of row, so 1st column to is ADDR 1, next pixel down is 4, 7, 10 etc...next column starts at the top again with 34 I believe.
I see options to change the start and switch between serpentine and colums, but the addresses all go across the top row instead of down.
Am I Missing something?
Re: RGB MAtrix addressing
Posted: Fri Mar 11, 2016 8:10 am
by OddSocks
There isn't an option for this at the moment but I am looking at trying to get this to work.
At the moment you can click on the RGB panel in the fixture list and then move elements around on the grid buy dragging them.
