Fixture creator 4.10.3 and caps lock
Posted: Tue Mar 08, 2016 5:19 pm
by michilson
Hey Guys
Love the software keep up the great work. I'd love to help test bugs I'm using this on a multi-Universe system and a Large lighting rig.
My Issues:
Inside the Lighting Fixture Creator inside the Channels Tab, The name Field only has about a 10 Character Value ( Try to Type in MAIN DIMMER ) You get (MAIN DIMME)
Also within the Description on the Capabilities section Same issue (Description only allows (10 Characters).
Thanks Please let me know if there is anything I can do to help beta test things for you guys!
Mike
Re: FIXTURE CREATOR Character ISSUE V4.10.3
Posted: Tue Mar 08, 2016 5:31 pm
by plugz
No issue here on linux.
Which OS are you running QLC+ on ?
Did this happen on older versions of QLC+ ?
Thank you
Posted: Tue Mar 08, 2016 6:36 pm
by michilson
Windows 7
Just upgraded to new 4.10.3
I am not aware of this issue on the older version however I do not have the old version to check.
Posted: Tue Mar 08, 2016 6:39 pm
by michilson
The issue seems to be related to CAPS LOCK
IF you CAPS all the letters you can only use 10 characters if not seems to be fine
Re: Fixture creator 4.10.3 and caps lock
Posted: Tue Mar 08, 2016 9:49 pm
Is your caps lock key broken ?
Cause you write in caps also in this forum, which is something I personally hate and find useless.
Please just don't.
