Korg Nano Pad & QLC
Sound Choice
Real Name: Ken Bromley
The only time the joystick icon comes up is if I use the XY pad. With the buttons...nothing.
mumbles wrote:Do you see a joystick in universe settings when you press nanoPAD buttons?
like the one on the right side of pic?
mumbles
Real Name: Justin
Disregard the settings in that picture it is strictly to demonstrate the joystick feedback indicator
OSX 10.10.5 QLC+ 4.9.1
Surface Pro4 Windows 10
Raspberry Pi B OLA 0.95
Raspberry Pi 2B QLC+
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
FTDI USB-RS485-WE-1800-BT XLR
Korg nanoKONTROL2
Korg nanoPAD2
Sound Choice
I am using a enttec dongle for my DMX (output) and the Nano pad as the input device. There is also a "NANOpad CTRL" which is not assigned to anything.
mumbles wrote:Disregard the settings in that picture it is strictly to demonstrate the joystick feedback indicator
mumbles
Real Name: Justin
To test more I will need your light profiles for
Sound Choice 6 channel par
Sound Choice 7 channel Par
Microh impossable LED
Microh Spitfire RGB
What happens if you set Roll/Flam Enable to Enable and set global velocity curve to const and const velocity value to 127
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Sound Choice
Sorry nothing happens still.
mumbles wrote:To test more I will need your light profiles for
Microh Spitfire RGB
Sound-Choice-6-Channel-Par.qxf
(1.89 KiB) Downloaded 91 times
Microh-Spitfire-RGY.qxf
(2.65 KiB) Downloaded 88 times
Microh-ImpossibLED.qxf
(1.45 KiB) Downloaded 71 times
Sound Choice
And the last one. BTW the Sound Choice ones are just generic pars. I did the profiles myself.
Sound-Choice-7-Channel-Par.qxf
(2.15 KiB) Downloaded 75 times
Sound Choice
I solved the problem. It turns out that the issue was not QLC or the Nano Kontrol software but the Nano pad itself. Found a video on youtube how to fix it and it is warking awesome now :) Thanks Mumbles for your help and patience.
mumbles
Real Name: Justin
That's great to hear you got it working !
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
plugz
Real Name: David
Can you share the video here so people who encounter this issue get to know how to fix it ? Thanks
Sound Choice
plugz wrote:Can you share the video here so people who encounter this issue get to know how to fix it ? Thanks
https://www.youtube.com/watch?v=spfYhzyjP6g
