Page 1 of 2
Re: Korg Nano Pad & QLC
Posted: Sat Mar 05, 2016 3:53 am
by Sound Choice
OK ... nothing..here are screen shots of my screens. And I also tried to use "global channel" and still nothing. And there are 12 pads not 16.
mumbles wrote:Sounds good
Posted: Sat Mar 05, 2016 4:57 am
by mumbles
Would you mind shairing shairing your QLC file
by Sound Choice
Which ones...all 3?
mumbles wrote:Would you mind shairing shairing your QLC file
by mumbles
Your *.qwx QLC workspace file
Sound Choice wrote:Which ones...all 3?
Posted: Sat Mar 05, 2016 5:04 am
by Sound Choice
https://www.dropbox.com/s/kmtvul4voaa6j2n/2016.qxw?dl=0
BTW thanks for your help! I am usually the one helping people on other forums but midi is kinda new to me.
by mumbles
Posted: Sat Mar 05, 2016 5:11 am
by mumbles
Pad Behavior should be momentary if you are using True scene function button in virtual console QLC will handle the toggleing not nanoPAD.
Global MDI Channel: 1
Velocity Curve: Nornal
BPM: 120
Midi Clock: Auto
by Sound Choice
mumbles wrote:Pad Behavior should be momentary if you are using True scene function button in virtual console QLC will handle the toggleing not nanoPAD.
BPM: 120
Midi Clock: Auto
changed Pad Behavior to "Momentry". saved it to the nano and still nothing.
Posted: Sat Mar 05, 2016 5:26 am
by mumbles
Im looking over your VC right now
Posted: Sat Mar 05, 2016 5:39 am
by mumbles
Do you see a joystick in universe settings when you press nanoPAD buttons?
like the one on the right side of pic?
by Sound Choice
The only time the joystick icon comes up is if I use the XY pad. With the buttons...nothing.
mumbles wrote:Do you see a joystick in universe settings when you press nanoPAD buttons?
Posted: Sat Mar 05, 2016 5:43 am
by mumbles
Disregard the settings in that picture it is strictly to demonstrate the joystick feedback indicator
by Sound Choice
I am using a enttec dongle for my DMX (output) and the Nano pad as the input device. There is also a "NANOpad CTRL" which is not assigned to anything.
mumbles wrote:Disregard the settings in that picture it is strictly to demonstrate the joystick feedback indicator
Posted: Sat Mar 05, 2016 6:13 am
by mumbles
To test more I will need your light profiles for
Sound Choice 6 channel par
Sound Choice 7 channel Par
Microh impossable LED
Microh Spitfire RGB
What happens if you set Roll/Flam Enable to Enable and set global velocity curve to const and const velocity value to 127
by Sound Choice
Sorry nothing happens still.
mumbles wrote:To test more I will need your light profiles for
Microh Spitfire RGB
Posted: Sat Mar 05, 2016 6:30 am
by Sound Choice
And the last one. BTW the Sound Choice ones are just generic pars. I did the profiles myself.
Posted: Sun Mar 06, 2016 4:09 am
by Sound Choice
I solved the problem. It turns out that the issue was not QLC or the Nano Kontrol software but the Nano pad itself. Found a video on youtube how to fix it and it is warking awesome now
Thanks Mumbles for your help and patience.
Posted: Sun Mar 06, 2016 3:10 pm
by mumbles
That's great to hear you got it working !
Posted: Sun Mar 06, 2016 3:17 pm
by plugz
Can you share the video here so people who encounter this issue get to know how to fix it ? Thanks
by Sound Choice
plugz wrote:Can you share the video here so people who encounter this issue get to know how to fix it ? Thanks
https://www.youtube.com/watch?v=spfYhzyjP6g
