mumbles wrote:Sounds good
Korg Nano Pad & QLC
- mumbles
- Real Name: Justin
Would you mind shairing shairing your QLC file
OSX 10.10.5 QLC+ 4.9.1
Surface Pro4 Windows 10
Raspberry Pi B OLA 0.95
Raspberry Pi 2B QLC+
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
FTDI USB-RS485-WE-1800-BT XLR
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
- Real Name: Ken Bromley
Which ones...all 3?
mumbles wrote:Would you mind shairing shairing your QLC file
- mumbles
- Real Name: Justin
Your *.qwx QLC workspace file
Sound Choice wrote:Which ones...all 3?
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
https://www.dropbox.com/s/kmtvul4voaa6j2n/2016.qxw?dl=0
BTW thanks for your help! I am usually the one helping people on other forums but midi is kinda new to me.
- mumbles
- Real Name: Justin
Your welcome
Sound Choice wrote:https://www.dropbox.com/s/kmtvul4voaa6j2n/2016.qxw?dl=0
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
- mumbles
- Real Name: Justin
Pad Behavior should be momentary if you are using True scene function button in virtual console QLC will handle the toggleing not nanoPAD.
Global MDI Channel: 1
Velocity Curve: Nornal
BPM: 120
Midi Clock: Auto
BPM: 120
Midi Clock: Auto
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
changed Pad Behavior to "Momentry". saved it to the nano and still nothing.mumbles wrote:Pad Behavior should be momentary if you are using True scene function button in virtual console QLC will handle the toggleing not nanoPAD.
BPM: 120
Midi Clock: Auto
- mumbles
- Real Name: Justin
Im looking over your VC right now
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
- mumbles
- Real Name: Justin
Do you see a joystick in universe settings when you press nanoPAD buttons?
like the one on the right side of pic?
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
The only time the joystick icon comes up is if I use the XY pad. With the buttons...nothing.
mumbles wrote:Do you see a joystick in universe settings when you press nanoPAD buttons?
- mumbles
- Real Name: Justin
Disregard the settings in that picture it is strictly to demonstrate the joystick feedback indicator
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
I am using a enttec dongle for my DMX (output) and the Nano pad as the input device. There is also a "NANOpad CTRL" which is not assigned to anything.
mumbles wrote:Disregard the settings in that picture it is strictly to demonstrate the joystick feedback indicator
- mumbles
- Real Name: Justin
To test more I will need your light profiles for
Sound Choice 6 channel par
Sound Choice 7 channel Par
Microh impossable LED
Microh Spitfire RGB
What happens if you set Roll/Flam Enable to Enable and set global velocity curve to const and const velocity value to 127
Microh Spitfire RGB
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Sorry nothing happens still.
mumbles wrote:To test more I will need your light profiles for
Microh Spitfire RGB
- Sound-Choice-6-Channel-Par.qxf
- (1.89 KiB) Downloaded 91 times
- Microh-Spitfire-RGY.qxf
- (2.65 KiB) Downloaded 89 times
- Microh-ImpossibLED.qxf
- (1.45 KiB) Downloaded 71 times
And the last one. BTW the Sound Choice ones are just generic pars. I did the profiles myself.
- Sound-Choice-7-Channel-Par.qxf
- (2.15 KiB) Downloaded 76 times
I solved the problem. It turns out that the issue was not QLC or the Nano Kontrol software but the Nano pad itself. Found a video on youtube how to fix it and it is warking awesome now Thanks Mumbles for your help and patience.
- mumbles
- Real Name: Justin
That's great to hear you got it working !
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
https://www.youtube.com/watch?v=spfYhzyjP6gplugz wrote:Can you share the video here so people who encounter this issue get to know how to fix it ? Thanks
