Hey guys,
while I was trying to get a fade out time for blackout working I possibly spotted a bug with the grandmaster.
Please have a look at the attached workspace. The slider in level mode controls a virtual fixture in a loopback universe. The respecting channel is set as external input for the grand master of the vc. When moving the slider, it seems that it is controlling the fade time and not directly the grand master. I really have no idea whats going on here.
When using the BCF2000 as external input for the gm, everything works fine.
This bug was already present in 4.10.2b.
Tested with QLC+ 4.10.3 RC on Xubuntu 14.04 64Bit, Qt5.
Grand master not remote controllable by loopback
- Real Name: Lukas
- grand master.qxw
- (2.4 KiB) Downloaded 77 times
- Real Name: Lukas
Thank you for your response! Remote controlling with a slider is working fine now. But what I actually wanted to achieve is a knob for blackout, which fades. So please have a look at the attached workspace, where I added a scene, which basically sets the Grand master channel to 0.plugz wrote:The virtual console GrandMaster has effect on the "Grand Master" channel.
Set the "Grand Master" channel to LTP to eliminate the issue
The problem is now, when I click the button, the GM in the vc moves down (expected), but when I click the button again, the GM stays at 0. What could I do to make it moving up again?
- grand master.qxw
- (3.03 KiB) Downloaded 81 times
- Real Name: David
I have no better solution than this.
Click the NEXT button on the cue list to change grand master state.
- grand master.qxw
- (2.9 KiB) Downloaded 98 times
- Real Name: Lukas
Nice solution, thanks!plugz wrote:I have no better solution than this.
I did it meanwhile with two buttons in a solo frame, but this would reduce it to one button, great!
Thanks again
