Feedback and button question
trentdiscos
Real Name: Matt Cartlidge
Hi all !
Firstly, I've only been using this software for a few days and it's amazing ! I was struggling with Avolites for the past couple of years and I wish I had discovered this software before. It's much better than any "paid for" lighting software out there. The user interface is brilliant and I have barely referred to the documents other than for helpful tips.
The only question I have so far is - how do I add a button to an existing frame ? If I drag a button in to the frame, the button doesn't actually dock. So if I move the frame around the button stays where it is.
Would appreciate any assistance and I'm happy to put my name forward for any testing etc.
Thanks,
Matt.
janosvitok
Real Name: Jano Svitok
Right-click in the frame, select Add... / Button
Please note that "accept child widgets" must be enabled in the frame's properties.
plugz
Real Name: David
And lastly, if you want to put an existing button inside a frame, you can do a cut-and-paste (select the button, hit ctrl+x, click inside the frame, hit ctrl+v)
