I'm new to the forum, in the meantime I want to do right away compliments on QLC + project.
I recently purchased the controller AKAI APC mini, and I found 2 problems
1-
I set the feedback following the manual:
http://www.qlcplus.org/docs/midiplugin.html
the problem is the feedback in the chaser, setting any parameters always returns the color green.
in the sample files to the chaser imposed feedback 2, 10 and I always return the green button.
instead with the "1" button on the left feedback it is perfect or changing the parameters I get the colors that interest me.
2-
the XY pad there are four presets, the first 3 are activated with buttons and remain active. the fourth "EFX 4" only works if I hold down the button, just release stops .
It seems functions like flash and then I can not get it to stay active.
wonder there are others with the Akai controllers that have the same problems?
Enclose a sample file
I apologize for my English
thank
Dino
AKAI APC mimi feedback & EFX
- Real Name: Dino Loss
- test-akai.qxw
- (8.45 KiB) Downloaded 76 times
AKAI APC mini
Behringer Eurolight LC2412
Enttec DMX USB PRO MK2
Windows 7 64
Windows 7 64
- Real Name: Peter Baumgartner
You are sure, that you set the upper and lower values right?
Lower means "off" state of the button, upper means "on", so lower=10=yellow, upper=2=green
Peter
Peter
Yes, right
any value "low" or "high" Feedback on the chaser turns me on
the key and is always green, it's on or off.
test with QLC+ 4.10.2b and 4.10.3 git
AKAI APC mini
Windows 7 64
Windows 7 64
Hm, this one does yellow and green for me, are you really sure, you did not use 0 and 255 in custom feedback?
