RGB Matric - RED Channel doesnt work
bibiblabla
Hey all
Great Tool!
But i have a problem with the RGB Matrix.
All works, except the RED Channel.
Any ideas? Would be great because i have a show tonight, and its a new problem for me..
Regards
Please attach here your qxw file and all your custom fixture definitions.
Also post your QLC+ version.
bibiblabla
Thanks for the answer.
I think i just do something wrong..
Version 4.10.1
Rhausdez15KOPIE - forum.qxw
(19.88 KiB) Downloaded 133 times
There was a problem in 4.10.1. Please try test version: 4.10.2 viewtopic.php?f=12&t=3135
I can't find what changed, but it should be fixed now. David, Massimo, do you remember? (It might be worth to mention it in the changelog.)
plugz
Real Name: David
bibiblabla wrote: Thanks for the answer.
Your Red channels are LTP.
janosvitok wrote: There was a problem in 4.10.1. Please try test version: 4.10.2 viewtopic.php?f=12&t=3135
I'm looking into it...
plugz
Real Name: David
The issue is caused by the Level mode slider that keeps forcing the LTP red channel to 0.
The issue has been fixed by this commit:
https://github.com/mcallegari/qlcplus/c ... d247645496
And the corresponding changelog line is:
* Virtual Console/Slider: in level mode, activate only in operate mode and don't hold forced LTP channels (David Garyga)
You can either fetch QLC+4.10.2 or change Red channels back to HTP.
siama22
Real Name: saima saleem
matric is some cchannel as well.. am looking for my matric result.
SSC Part 2
