[HEADS UP] Help needed to test incoming version 4.10.0 - Round 2
sbenejam
Re: [HEADS UP] Help needed to test incoming version 4.10.0 - Round 2
Post by sbenejam » Mon Oct 12, 2015 9:41 am
Tested on Ubuntu 15.04 qlcplus test packages Qt4 ans Qt5 versions all seems to work well with older projects. Hardware connected Enttec DMX USB, NanoKontrol2, USB audio interface and Digitus DA-70157 USB RS-485 adapter (Chipset: FTDI / FT232RL). Not tested with real fixtures, DMX output tested with DMX homemade tester.
Post by mcallegari » Mon Oct 12, 2015 10:18 am
QLC+_4.10.0-TEST-20151012.dmg uploaded !
Ovis
Real Name: Ovidijus
Post by Ovis » Mon Oct 12, 2015 10:18 am
mcallegari wrote:QLC+_4.10.0-TEST-20151012.dmg uploaded !
Not crashes anymore with speed dial properties:) Thanks
ENTTEC PRO Mk2
AKAI APCmini
bestdani
Real Name: Daniel
Post by bestdani » Tue Oct 13, 2015 1:06 pm
changelog wrote: Video: (Windows) Videos now have a black background, like all the other platforms
This is unfortunately not true for my Win7 x64 tests.
I tested it also with different kinds of videos, activated fullscreen mode, activated Windows Aero style and both on my laptop and desktop win7 installation.
Post by mcallegari » Tue Oct 13, 2015 1:06 pm
The tests I've done were on Windows 7 64bit !
The screenshot you've posted is not Windows 7...is it ?
bestdani
Real Name: Daniel
Post by bestdani » Tue Oct 13, 2015 4:12 pm
It is, I just used the classic skin.
Another screenshot:
Is it really the linked test build that is supposed to include that or is this accidentally only valid for any custom git build (I did not build from git on windows so far).
Is there anything I can do to investigate the problem if it should really work in that constellation?
Morphinus21
Real Name: Dominik
Post by Morphinus21 » Tue Oct 13, 2015 4:26 pm
Same here,
tested it on Windows 10 x64 with the same Version from bestdani.
[EDIT] image cut. I believe you :)
Greeting
Dominik
Post by mcallegari » Tue Oct 13, 2015 4:48 pm
Oh, crap. Sorry guys.
I've made the video changes right after building the 20151010 versions !
The changelog is what's on GIT right now. Sorry for the misunderstanding.
I'm gonna build an updated Windows version.
I've got bad luck anyway. What I need to be tested is not tested, and what I consider marginal is the first thing to be tested :(
Post by mcallegari » Tue Oct 13, 2015 5:44 pm
QLC+_4.10.0-TEST-20151013.exe uploaded
bestdani
Real Name: Daniel
Post by bestdani » Tue Oct 13, 2015 7:25 pm
Ok it works flawlessly now on win7 x64. :)
If you can direct to what's most important to be tested first I could start with testing this if possible, since not surprisingly I was going to test the enhancements that were important to me first. :mrgreen:
