One Audio Trigger for multiple Chaser
Epity
Hello Everybody,
I want to know if it is possible to use one Audiotrigger for multiple Chaser.
I'm using qlc+ 4.9.1 on a Windows7 x32 prof system to control 4 Led Spots via an USB Interface. In the VC i designed my elements which includes severals Buttons for different Chaser. To control the Speed for all Chaser i added one Speed Dial. All is working fine.
If i want to Control "Chaser 1" by Sound, i have to add an Audiotrigger and a CueList to control this Chaser. For the next Chaser "Chaser 2" i have to do the same.
For more than two Chaser the Control needs a lot of Space in the VC, i want to avoid.
Is there an Option to use one Audiotrigger and one CueList for multiple Chaser. For Expample: I start the Audiotrigger and with a Button i match Chaser i want to the CueList.
I would be very happy if anybody can help me.
Cheers
Epity
adko
Real Name: Chad Kouse
Just wondering if you ever found a solution for this?
