[SOLVED] Issue with QLC+ window maximizing and not allowing QLC+ to fit screen (Mac OSX)
mumbles
Real Name: Justin
Post by mumbles » Thu Aug 27, 2015 1:03 am
Hi
I was wondering if anyone running QLC+ 4.9.1 on OS X 10.10.5 has had an issue with QLC+ screen expanding off screen and not allowing window to be resized to fit screen after selecting simple desk? Also after entering simple desk and screen expands; Full screen mode doesn't size correctly either making it difficult to use QLC+ with the controls on the left and right sides cutoff?
Here are some screen shoots showing what I mean by left & right of screen being cutoff. and configuration Im having issues with.
if someone could help me figure out a way to prevent this from expanding Id greatly appreciate it!
TMS-QX-K.qxf
(3.1 KiB) Downloaded 44 times
RGB-Loopback-Device.qxf
(1.53 KiB) Downloaded 53 times
Desktop_Layout_temp.qxw
(171.21 KiB) Downloaded 38 times
OSX 10.10.5 QLC+ 4.9.1
Surface Pro4 Windows 10
Raspberry Pi B OLA 0.95
Raspberry Pi 2B QLC+
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
FTDI USB-RS485-WE-1800-BT XLR
Korg nanoKONTROL2
Korg nanoPAD2
mumbles
Real Name: Justin
Re: Issue with QLC+ window maximize and not allowing it to fit screen
Post by mumbles » Thu Aug 27, 2015 1:06 am
Screenshoot
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
mumbles
Real Name: Justin
Re: Issue with QLC+ window maximizing and not allowing QLC+ to fit screen
Post by mumbles » Thu Aug 27, 2015 1:59 am
Ive just noticed to trigger this problem if it doesn't happen as soon as QLC+ loads file, selecting another tab and going back to simple desk seams to triggers issue every time.
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Post by mcallegari » Thu Aug 27, 2015 10:47 am
This is known "issue" and it happens on lower resolutions.
Which screen resolution are you using ?
In any case, you can set the number of faders that the Simple Desk should display, so it doesn't force QLC+ to resize horizontally
See 4.1 here: http://www.qlcplus.org/docs/parameterstuning.html
mumbles
Real Name: Justin
Post by mumbles » Thu Aug 27, 2015 11:58 am
Im using a MacBook pro 2010 with a sreen resolution I believe that is 1280x800.
Thanks for tip. Ill try changing fader count this evening.
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
mumbles
Real Name: Justin
Post by mumbles » Thu Aug 27, 2015 6:06 pm
could someone please tell me what I'm doing wrong when trying to change simple desk fader count? If I understand correctly I need to add two lines at the bottom of net.sf.Q Light Controller Plus.plist. as shown in pic. Is this correct? It must not be because I keep getting all 32 faders when I launch QlC+
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
Post by mcallegari » Thu Aug 27, 2015 6:06 pm
mumbles wrote:could someone please tell me what I'm doing wrong when trying to change simple desk fader count? If I understand correctly I need to add two lines at the bottom of net.sf.Q Light Controller Plus.plist. as shown in pic. Is this correct? It must not be because I keep getting all 32 faders when I launch QlC+
According to the documentation you need to use a backslash and not a dot.
See paragraph 3 / Mac OSX: http://www.qlcplus.org/docs/parameterstuning.html
Also I'm not sure about <integer>. I can't recall right now the tests I've done on OSX. Have you tried with <string> ?
mumbles
Real Name: Justin
[/quote]
Also I'm not sure about <integer>. I can't recall right now the tests I've done on OSX. Have you tried with <string> ?[/quote]
Ive tried these combos and still no luck.
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
mumbles
Real Name: Justin
Post by mumbles » Thu Aug 27, 2015 7:40 pm
It appears that when I launch QLC+ after making changes to net.sf.Q Light Controller Plus.plist QLC+ is rewriting file back to default code. I know code is saved because I closed out of editor and reopened file in editor to verify file was saved then open QLC+ still 32 faders. So I closed out QLC+. Reopened editor opened net.sf.Q Light Controller Plus.plist and code changes are gone.
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
pengumaniac
Real Name: Manfred Flintstone
Post by pengumaniac » Thu Aug 27, 2015 10:47 pm
stop that tweaks (if not slider/page, perhaps changing "view mode" can extend, too)
and just try to save your workspace NOT, if simple desk is on the upper hand
switch then to VC, save, close QLC+ if you can, and start it new again (maybe w/ fullscreen & operate), this helps me also on 1024x768...
but maybe you want to use that cue stack "thing" ...
Gentoo | profile=desktop | LXDE | QLC+ qt4-build / openSUSE 13.2-x86_64 | KDE | QLC+ qt5-rpmbuild
The best way to predict the future is to invent it. (Alan Curtis Kay) - I'd like to emerge -avuND world, but there are no news in sync for stable updates
