Page 1 of 2
OSC Connection fails after a while (OSX & QLC 4.9.1)
Posted: Sun Aug 23, 2015 10:29 pm
by teackele
Hello all
The 4.8 branch had a very stable osc implementation. With 4.9 version i'm experiencing problems after a while.
My setup
-OS 10.8
-QLC 4.91.
-Enttec DMX USB Pro
-MacBook connected to wifi router
-iPhone 5s with touch OSC
Haven't got it pinpointed down exaclty yet, but it seems that osc input to qlc+ stops working once the iphone has last connection with the wifi and reconnects.
Known bug?
Regards teackele
Re: OSC Connection fails after a while (OSX & QLC 4.9.1)
Posted: Mon Aug 24, 2015 11:57 am
Hi, the OSC plugin has been completely rewritten on QLC+ 4.9.0.
It is possible that it still has glitches, but I need a precise way to reproduce issues.
Can you please try to identify when the plugin stops receiving data from touchOSC ?
Maybe it's something related to some network timeout.
I'll try to do some more tests myself.
Posted: Tue Aug 25, 2015 10:43 pm
by teackele
thx for the swift response.
i'll try to explain it when it happens so you can possibly recreate it. I can also send you files (qlc+ setup, osc input profile and touch osc screen/interface)
-startup qlc plus
-load a file with buttons connected to osc plugin and custom profile on universe 2 (input on universe 1 is midi)
-start touch osc on iphone (haven't tested on android yet). iphone is connecte through wifi with qlc (mobile networking like 3g and 4g turned off)
-disable wifi on the iphone or walk out of range of wifi network
-reconnect to wifi or walk in to range until wifi automatticaly reconnects
-try to control qlc+ with the osc on the iphone again
Can i enable file logging of debug output somewhere so i could send you log file output?
Regards Teackele
BTW our installation running on QLC+ (dmx rgb led in every duck and DMX relay board operating valves controlling water flow) http://www.noorderzon.nl/uploads/opengr ... 2869431858
Posted: Wed Aug 26, 2015 8:42 am
by plugz
Is the iphone connected directly to the computer running QLC+, or is there a wifi router between the 2 devices ?
teackele wrote: BTW our installation running on QLC+ (dmx rgb led in every duck and DMX relay board operating valves controlling water flow) http://www.noorderzon.nl/uploads/opengr ... 2869431858
This is brilliant!
Posted: Wed Aug 26, 2015 10:53 am
by teackele
Thanks :D
There's a wifi router between the iphone and qlc+
-the touter has no internet acces
-network is 192.168.5.0
-qlc+ computer has fixed ip address (192.168.5.10)
teackele
by mumbles
teackele wrote:Hello,
Thanks :D
teackele
I don't know if this will help or not but when Im using my iOS devices running home automation app's on networks without internet I have to configure my phone differently to make apps run stable.
On your iPhone under wifi> network Info> (Set static IP and sub mask ) (Leave Router, DNS, and Search Domains BLANK.)
This forces the iPhone to use cell network for internet and stop probing LAN for internet. but still allows iPhone access to LAN devices.
Posted: Wed Aug 26, 2015 11:20 am
Hi teackele,
I just made a quick test with touchOSC on Android and QLC+ on Linux.
- loaded a QLC+ project
- controlled a few widgets of the virtual console
- closed touchOSC
- turned off WiFi on the phone
- turned WiFi back on
- started touchOSC
It's working as expected, and there's a technical explanation for it.
OSC works with UDP packets so the communication is "connectionless". It means that there is no check between the hosts if the connection is up or down. They just send/receive packets no matter if there is someone listening on the other side.
So you can even restart QLC+ while touchOSC is open on the phone and OSC will still work (as well as ArtNet and E1.31)
Now, I can do the same test on OSX, but being a *nix-based OS, I expect to see the same I've seen on Linux.
Unless it depends on touchOSC on iOS, then I'm afraid I can't help.
Awesome use case indeed !
Can you tell us more or point us to pictures/videos or whatsoever ? :)
Posted: Wed Aug 26, 2015 12:01 pm
by plugz
Have you tried stopping and relaunching TouchOSC after the reconnection is done ?
What do you have to do to make the setup work again ?
Posted: Thu Aug 27, 2015 2:41 pm
by teackele
Hello
There are 2 ways to make the osc work again
-restarting QLC+
-switching between inputs (127.0.0.1 and 192.168.5.10). just switching between them makes it work again
teackele
Posted: Fri Aug 28, 2015 10:09 am
by teackele
Hello
I've been looking at the source code of the OSC plugin. It's pretty straightforward. I notied that the change beteween version 4.8 and 4.9 is basically that youve deciced to not use LibLO anymore and use the QUdpSocket of the Qt Framework instead.
I don't know with what version of Qt the OSX version is compiled, but googling on QUdpSocket gives some hits on bugs in the QUdpSocket implementation. Might this be the suspect?
Regards Teackele
teackele wrote:I don't know with what version of Qt the OSX version is compiled,
version 5.4.2
teackele wrote:but googling on QUdpSocket gives some hits on bugs in the QUdpSocket implementation. Might this be the suspect?
Can you please point me to these hits you found ?
Posted: Sat Aug 29, 2015 9:45 am
by teackele
Posted: Sat Aug 29, 2015 10:46 am
Thank you very much.
Qt 5.5.1 is scheduled to be released in September and should contain the fix for this problem.
I will produce a TEST version with Qt 5.5.1 and notify you here.
Posted: Tue Sep 01, 2015 10:03 am
by teackele
Thx. I'll test it as soon as it's available
Teackele
Posted: Tue Sep 01, 2015 10:20 am
by plugz
This precise bug was not present in Qt5.4.1, can you test with Qt5.4.1 ?
Posted: Tue Sep 01, 2015 10:27 am
by teackele
Hello ,
Will try, but got my next gig tomorrow in germany, not sure i have the time to create a build environment on my macbook before that
regards teackele
Posted: Tue Sep 08, 2015 6:29 am
by TolikKozak
I am looking for a good osc/midi controller for my phone to control qlc+ with. Awaiting your update. TouchOSC is the only one i see that looks well done and popular, but not sure if i want to invest in it yet as I dont know if it will work. Let us know when you can. :)
Posted: Tue Sep 08, 2015 2:45 pm
by mumbles
Hi TolikKozk
It sounds like your looking for an alternative to TouchOSC? I was the same way about buying TouchOSC. I tried 3 or 4 OSC apps before purchasing TouchOSC. In my experience its definitely the easiest to customize, integrate with QLC+, and its stable. Its not free but if you want an OSC app for your phone I highly recommend it.
Posted: Wed Sep 09, 2015 9:55 am
by teackele
Hello
Haven't had time to ompile a different version of Qlc for my last gig. But on my way back I got an idea of which may be the problem. My Touch osc is set up to send ping and accelerometer messages. This causes lots of OSC traffic. My guess now is that the Qt UDP implementation (or qlc+) probably chokes somewhere (filled buffer or similar)
Haven't tried it yet without accelorometer and ping messages yet though.
regards teackele
regards teackele
According to the Qt bug report on the UDP socket implementation, that can actually be the cause. Lot of traffic disturbs the socket.
I am eagerly waiting for Qt 5.5.1 to be released. Should happen any day now.
