nanoKONTROL2 great
Posted: Wed Jul 08, 2015 8:14 pm
I tested the nanoKONTROL 2 and it works very well. Congratulations again for the good work.
This a very good solution for small budget.
Official forums of the QLC+ project
http://www.qlcplus.org/forum/
You could use the Korg Kontrol Editor configuration software to set the LED MODE to EXTERNAL to get the leds working. The Nanokontrol2 LED MODE is set to INTERNAL by default.Ovis wrote:Don't want to create new topic so I will ask here about this controller.
First, can't get leds to work. What I need to do that the led will stay on then button from VC is in ON mode. Now led just lights until I release button.
Second speed dial mapped to knob, but when I rotate it it dosn't move, only time changes. It's a bug? Or it shoudn't rotate?:)
I didn't realize you could change led mode. I thought it was a limitation with QLC+. Ill have to try this. If it works that's going to make everything more intuitive and nice! I assume this is possible with the nanoPad2 also? Thanks for the tip!sbenejam wrote:You could use the Korg Kontrol Editor configuration software to set the LED MODE to EXTERNAL to get the leds working. The Nanokontrol2 LED MODE is set to INTERNAL by default.
Where do I find the “LED MODE” to VCH Anne it to external?sbenejam wrote: ↑Thu Oct 22, 2015 6:42 pmYou could use the Korg Kontrol Editor configuration software to set the LED MODE to EXTERNAL to get the leds working. The Nanokontrol2 LED MODE is set to INTERNAL by default.Ovis wrote:Don't want to create new topic so I will ask here about this controller.
