[HEADS UP] beta testers needed for incoming 4.9.0 version
jadaudiodesign
Real Name: Jean-Daniel Garcia
Re: [HEADS UP] beta testers needed for incoming 4.9.0 version
Post by jadaudiodesign » Mon Jun 22, 2015 5:24 pm
i just try install....and prog say impossible start prog cause libgcc_s_dw2-1.dll missing
Post by mcallegari » Mon Jun 22, 2015 5:24 pm
jadaudiodesign wrote:i just try install....and prog say impossible start prog cause libgcc_s_dw2-1.dll missing
Hi, thanks for the feedback.
To my knowledge that DLL shouldn't be needed anymore.
Have you uninstalled any previous version of QLC+ first ?
Maybe overwriting an existing installation doesn't work
sbenejam
Post by sbenejam » Tue Jun 23, 2015 6:10 am
On Ubuntu 15.04 compiled with qt5.4.1, NanoKontrol2 and Enttec DMX USB Pro. I tested some old workspaces and all work as expected. The Nanokontrol2 and Enttec DMX USB Pro also works (without fixtures connected). The audio playing works well. Video playing without gstreamer0.10-ffmpeg installed shows a black screen, audio from video is played and to stop playback should close the program. Installing gstreamer0.10-ffmpeg video playback works as expected.
Good job!!
Post by mcallegari » Tue Jun 23, 2015 6:10 am
sbenejam wrote:On Ubuntu 15.04 compiled with qt5.4.1, NanoKontrol2 and Enttec DMX USB Pro. I tested some old workspaces and all work as expected. The Nanokontrol2 and Enttec DMX USB Pro also works (without fixtures connected). The audio playing works well. Video playing without gstreamer0.10-ffmpeg installed shows a black screen, audio from video is played and to stop playback should close the program. Installing gstreamer0.10-ffmpeg video playback works as expected.
Good job!!
Thanks Santiago !
perlinpinpin
Post by perlinpinpin » Sat Jun 27, 2015 7:04 pm
Hi! on Win 7 Qlc doesn't start : libgcc_s_dw2-1.dll is missing... You have to copy/paste the dll from another folder to qlc folder, then it starts. Let's give a try to this new release!
Flo
Real Name: Florian
Post by Flo » Sat Jun 27, 2015 7:04 pm
perlinpinpin wrote:Hi! on Win 7 Qlc doesn't start : libgcc_s_dw2-1.dll is missing... You have to copy/paste the dll from another folder to qlc folder, then it starts. Let's give a try to this new release!
Same here with 4.9.0 final and Windows 8.1.
BTW: The message board here seems to have a bug: If you quote something the new entry gets the same date and time as the quoted entry.
Post by mcallegari » Sun Jun 28, 2015 7:41 am
As usual, one day after the release...
QLC+ works in my Windows 7 system without that DLL. I removed all my development folders, so my system doesn't have that libgcc_s DLL anywhere.
Have you tried to uninstall previous versions of QLC+ as suggested in the announcement ?
Flo
Real Name: Florian
Post by Flo » Sun Jun 28, 2015 7:41 am
mcallegari wrote:Have you tried to uninstall previous versions of QLC+ as suggested in the announcement ?
Just did it again this moment: I uninstalled and deleted every file of QLC+ on the hard drive I could find and reinstalled 4.9.0. And it still wants to have that DLL.
How weird, I couldn't really explain that.
Anyway, since it seems a new package is needed, I will include that DLL as well.
Post by mcallegari » Sun Jun 28, 2015 2:40 pm
Windows package re-upped with the missing DLL. It also contains a last minute Stageprofi fix.
