Hi. I am learning QLC+ to replace my hardware controller, Chauvet Obey 70.
I created a fixture definition for American DJ Starball. The first time I used this in building my lighting set, it worked. First I added my Chauvet 4Bar, then I created the fixture Starball. I opened up the saved workspace and the starball now only has one channel, not two. All the settings in my fixture definition are gone! I deleted the fixture and recreated it with all the values, etc. I used the fixture again in a workspace and it does the same thing, resetting all the channels and values to a generic blank.
Without this light, I do not want to go on learning QLC+. I really need help here. I would certainly appreciate it.
Fixture problems
- pipolino419
- Real Name: Rodolfo
Here viewforum.php?f=6
If pipolino's definition didn't fix your problem, please post: operating system, qxw file, and the fixture definition.
My blind guess: Did you store the fixture in the proper folder? see http://www.qlcplus.org/docs/questionsan ... ser-folder
ocus,
help us help you. Post: QLC+ version, your custom fixture definition, your qxw file, step-by-step recipe to reproduce the problem with expected behavior (e.g. do this and that, and QLC+ does this and it should do that instead).
If you need fast answers, you need to ask clear questions
