Installation crash...
Sergi Font
Hi
I'm not shure if it's a bug, so i decided to post here first.
When i'm installing qlc+ for amd64 on linux ubuntu 12.04 the installation give back an error.
I post the error.
Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 401237 files and directories currently installed.)
Unpacking qlcplus (from .../qlcplus_4.1.1_amd64.deb) ...
dpkg: error processing /home/celedabcn/Descargas/qlcplus_4.1.1_amd64.deb (--install):
trying to overwrite '/etc/udev/rules.d/z65-enttec-dmxusb.rules', which is also in package qlc:i386 3.2.2
dpkg-deb (subprocess): data: internal gzip write error: Broken pipe
dpkg-deb (subprocess): failed in write on buffer copy for failed to write to pipe in copy: Broken pipe
dpkg-deb: error: subprocess returned error exit status 2
Errors were encountered while processing:
Massimo Callegari
I've just downloaded the package and installed it on Ubuntu 12.04 64bit.
It works ok.
Sourceforge is experiencing a lot of problems lately. Try again ?
P.S. I see you have QLC 3.2.2 i386 installed. Maybe you should remove it ?
