OLA doesnt listen to localhost. Start OLA with option "-l3" and check your output or use the "ola_dev_info" command to find out under which ip OLA is running. If you are not connected to a LAN, you have to set a static ip manual on one your network interfaces.
OLA Support
Hi offtools,
OLA is started with the option -l3, und the static ip of the interface is set:
ola_dev_info
Device 1: ArtNet [10.0.0.1]
but i can't get the OLA-plugin for QLC+ to work.
ola_dev_info
Wait. At this point I don't understand if you don't see the OLA universes listed in QLC+ or if you see them but can't get them work.
Can you please open a terminal (Apps->Utilities->Terminal) and type:
which olad
and report the output here ?
Regarding translations, you need to install Qt Linguist for OSX:
http://code.google.com/p/qtlinguistdown ... loads/list
then Download QLC+ source code, extract it and open all the _de_DE.ts files in the tree with Qt Linguist. The biggest one is ui/src/qlc_de_DE.ts
which olad
Here is the output:
131-heiko-faniengs-macbook-pro-wlan:~ heikofanieng$ which olad
/opt/local/bin/olad
Maybe thats the problem - /opt/local/bin instead of /usr/local/bin/olad ?
I don't chooes this path - installed ola with macports.
/opt/local/bin/olad
Hi Heiko, I've just uploaded QLC+ 4.1.1b which looks for OLA in /opt/local.
Please let me know if it works, so I'll stick with this solution for the next releases.
I've included also your translation. Please check if everything's ok.
Thank you Massimo. But i can't find the Download for QLC+ 4.1.1b for testing. And maybe i can do some more translation over Christmas Days:) Now i found out to put the translations directly in my QLC+ Installation path and i can check it dircetly in the context of using QLC+
I think I'm starting to hate Sourceforge.
I've uploaded the file like 5 times and SF always set it to pending.
Let's wait a bit and see if they decide to make it available
In the meantime...here it is:
http://dl.dropbox.com/u/4102185/QLC%2B-4.1.1b.dmg
- QLC%2B_4.1.1b_online.png (22.17 KiB) Viewed 1848 times
You make me happy bevor Christmas Now OLA works. Now i can start at the first time to use DMX on my Mac
