No feedback on Korg nanoKontrol 2
Smasty
Hello, I'm new to using QLC+ as a DMX controller. I have QLC+ 4.8.3. installed on my Debian Jessie laptop, with a Korg NanoKontrol 2 as my input/feedback device. The problem is, the feedback doesn't work - the buttons on the Korg do not stay backlit when a coresponding button in virtual console is selected. The buttons only flash with red backlight, and then stay dark. It's annoying, since there is no visual feedback for running functions.
Do you have any ideas how I could fix this issue?
Thanks.
Santiago Benejam Torres
The NanoKontrol2 has an option called LED Mode that can be set to Internal or External. Set it to External with the software provided by Korg. I don't know if works with Wine, I changed it from Windows XP running in Virtualbox on Ubuntu.
And do not forget to mark midi input and feedback checkboxes in the Inputs/Outputs tab.
Smasty
Thank you very much, it works now.
lLapisl
Hello! I have the same problem. I did everything as it is written, but the NanoKontrol2 buttons do not respond. They work only in Passthrough mode
