READ BEFORE POSTING - Issues reporting guidelines
Massimo Callegari
Here's some suggested guidelines to improve the efficiency of this forum and help users that might run into your same questions.
  • Read the QLC+ documentation before posting here. In many cases you'll get the answer you were looking for. Online version here.
  • Search the forum before posting, in case a similar (or same) question has already been asked/answered.
  • If you're a gentleman, saying "Hi" costs nothing. Does it ?
  • Please write in English and in a language that everybody can understand. Keep in mind there are people all over the world reading you. Remember also the good old punctuation taught in school? :)
  • Do not write in caps. It's rude and useless, since you won't have more chance to be answered
  • If you're posting an issue you found, the more information you provide, the more chance you have to get an answer. Please indicate the versions/types of all the softwares/hardwares involved in your question (Operating System, QLC+ version, DMX adapter, Audio card, etc..)
  • If you run into a sistematic issue, please explain the exact procedure to reproduce it and, in case, share a simple project which shows the issue.
  • Always consider that if something doesn't work in your environment, it doesn't mean it won't work for everybody.
  • Always keep in mind that this is a project sustained by pure volounteering. No need to get upset if you don't find what you're looking for.
  • Read the documentation first !
To make it plain and simple: contructive and detailed posts = help, pure and rude complains = no help
As a reminder, if you find QLC+ useful or you use it for professional purposes, please consider a donation to the project.
You can find the button at the bottom of the homepage: https://www.qlcplus.org/
