[FIXED] Tabs order in scene editor
willmodelisme
I come back with a new topic on the tab order in the function editor.
Each time I load a workspace after opening QLC+ the order of the fixtures change and the tab are not sequential form 1 to 8 (in may case 8 fixtures).
It is random, no rule seems to be emerging.
QLC+ 4.10.3 TEST
basic.qxw
(27.59 KiB) Downloaded 153 times
Enttec DMX USB Pro
Windows 10
allendunn
Real Name: Allen Dunn
That's problem for me, too.
pacco
It would be great to have the possibility to change the tab order manually (and "save" it) in the scene/function editor.
Also when I switch from "tab viev" to "all channels view", it would be great to arrange the order of the fixtures.
Regards
Pacco
yokosuna
I agree to that: its completly irritating and should be fixed
Now fixed on GIT
yokosuna
Now fixed on GIT
If you mean 4.10.4 GIT than it still doesn´t work for me:
- create a scene
- add 5 generic fixtures ... the are ordered #1 thru #5
- create another scene
- go just back to the first scene ... order is scrambled: #4, #3, #2, #1, #5
yokosuna wrote:
Now fixed on GIT
I mean it is fixed in the current GIT sources.
I just tested what you've written above and it works for me.
You haven't written where "4.10.4 GIT" comes from (OBS ? built yourself ? where ?), so most likely you're testing the wrong GIT version
yokosuna
plugz
Real Name: David
yokosuna wrote: I went to this topic: viewtopic.php?f=12&t=3135
and this file: http://www.qlcplus.org/downloads/test/Q ... 160419.exe
This version is from 2016-04-19. The fix was made on 2016-04-25.
yokosuna
Thank you, I was not aware that the link has the same version but is outdated. Since I´m not able to build by myself - can anyone post a current build ?
Thx a lot.
yokosuna
Since I´m not able to build by myself - can anyone post a current build or link ?
Thx a lot.
Push
Push what ?
If no new windows build is available, it means nobody has time or the chance to do it.
