QLC+ Web interface and multiple NIC
Posted: Thu Jan 05, 2017 9:24 pm
New here and would like to start by saying thanks to everyone who contribute to this great software. As I'm learning it, I believe I found an issue with the QLC+ Web Interface on Windows 7 running with other Network Adapter like VirtualBox NIC. QLC+ seem to take for unknown reason my Virtual adapter, I suspect it is may be the first in the list of adapter. Doing a NETSTAT you can clearly see the port 9999 assign to my VM adapter:
Below is the QLC+ Log file by using -d 0 -g -w. I try other level but did't get anything else.
I believe it is not relate to VirtualBox but anyone who may have more than 1 adapter and unlucky if it is the first one. Unfortunately I can't disable the VM host Adapter to test it so the only alternative seem to uninstal VirtualBox.
Is there a way to specify the adapter when using Web option? Or manually change it in Windows or QLC+ system environment?
Starwolf73
TCP [::1]:64123 Studio-PC:9999 TIME_WAIT
TCP [::1]:64124 Studio-PC:9999 TIME_WAIT
TCP [::1]:64125 Studio-PC:9999 TIME_WAIT
TCP [::1]:64200 Studio-PC:9999 TIME_WAIT
TCP [::1]:64201 Studio-PC:9999 TIME_WAIT
TCP [::1]:64204 Studio-PC:9999 TIME_WAIT
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "LH-Laser LH-RGB222"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Lindax Moving Head Double Wash/Beam Led"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Phenix PAR36-RGB"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "lightmaXX Platinum CLS-1"
"C:/QLC+/Fixtures/lightmaXX-Platinum-CLS-1.qxf" not in FixturesMap.xml
Loading USBDMX.DLL failed.
void IOPluginCache::load(const QDir&) "velleman.dll" doesn't contain an I/O plugin: "Cannot load library C:\\QLC+\\Plugins\\velleman.dll: The specified procedure could not be found."
DecoderMAD: cannot initialize. Source file doesn't exist.
bool EnttecDMXUSBPro::extractSerial() "DMX USB PRO" gave malformed serial reply: "0" "0" "0" "0" "0" "0" "0" "0" "0"
Starwolf73
