Cue List ignores submaster
EthanBenj
Real Name: Ethan Benjamin
I've had an issue with the latest version. Attached is the workspace. On the virtual console I have two cue-lists in frames with sliders set to submaster. In past versions,I could advance through the cue-list with the slider at 0 and nothing would be output. Now,the cue-list is output even if the slider is at 0. I've tried re-creating the cue-lists and it still does not work.
Windows 10
QLC+ Version 4.11.1
Regards,
Ethan
Ethan Main Showfile V2 Akai APC.qxw
(145.34 KiB) Downloaded 39 times
EthanBenj
Just to add,I re-installed an older version and it worked as it should so it is definitely and issue with 4.11.1
Regards,
Ethan
Duplicate of this thread
EthanBenj
I just noticed it. My apologies.
EthanBenj
Will this be addressed in the next release? And without sounding rude,does anyone know a ballpark for the next release?
Regards,
Ethan
EthanBenj
Or,do you know how to add the corrected files from GIT? I apologize for my ignorance,I'm not really a developer.
Regards,
Ethan
@Ethan, 3 posts in a row
There are TEST versions here: viewtopic.php?f=12&t=3135
Their purpose is exactly to include development fixes, but they're not quite suitable for productions
