No Backgroundpicture in XY-Pad
MaxMeyer
Hello Forum,
i want to insert a Backgroundpicture into a XY-Pad. I can select a file but nothing happens.
It would be nice to have a Plan of the Stage as Background of the XY-Pad.
Max
Max,
As I told you before you are in a 3D environment. I'm quite sure you will be very disappointed with the outcome. You won't be able to pinpoint your heads to the position you think they will be...
I think you are seeking some kind of visualisation while pre-programming your show?
Search this forum for visualisation solutions
or have a cup of thea and get acquainted with Massimo's video #7 -> therein he shows how to use heads (EFX) and a visualiser.
(the problem you will face with XY-pad and background is that when you 'zoom' ergo you limit the XY-pad, the image should be scaled and this is not functioning)
MaxMeyer
Hello GGGss,
so the program detects that i want to insert a "wrong" content and dont show it?
Max
No,
The image will stay the same whatever you do on the pad.
Just try it and see for yourself
MaxMeyer
I would try it but as i said before, it dont work. After i select a picture in the filepicker nothing happens.
