4.11.1.162 - Bug in DMX monitor
lightuser
When creating a cue list and manually controlling it with faders in blend mode, all the lights stay on when the first loop is done.
It should go back to step one (0 lights)
I don't know if only the monitoring is doing it wrong or if the real DMX output is also making the same fault (can't test it right now, i dont have a dmx interface with me)
demonstration of the bug in QLC+ 4.11.1.162 (latest test version)
https://youtu.be/v7WcbkK_2s8
Can you try the same without infinite fade in/fade out times (as they don't have any sense)?
lightuser
When changing the fade in and fade out time to '0' and keeping the hold time to 'infinite', the problem is fixed.
-> by changing the timing, I discovered a new bug
viewtopic.php?f=33&t=11460
