I'm using a Korg nanoKONTROL2 to control sliders in a multipage frame widget.
On the second and later operate mode launches, the physical slider operates the sliders of all the pages. you have to force a page change to go back to "normal" behaviour.
steps to reproduce :
- in fixtures, add 4 dimmers
- in virtual console, set up a 4 pages frame with a slider in each page, attach the track left and right button to change pages (or any other button)
- for each page, set the slider to level mode for one of the 4 dimmers, and attach the first nanoKONTROL2 slider as external input.
- go to operate mode and open the dmx console
- operate the physical slider, the VC slider of the page react, along with the according dimmer
- if you change page, the physical slider modify the right slider/dimmer
- go to design mode and back to operate mode (EDIT : or disable/enable the frame widget)
- operate the physical slider, all the 4 dimmers react (=> expected to be only the one of the current page)
- if you change page, the physical slider modify only the correct slider/dimmer
if you close QLC+ and open the same workspace, the first operate mode launch is ok, but no the later ones.
please find attached a sample workspace,
Did I configure something wrong or is it an issue ?
QLC+ version 4.11.0 on debian 9.1 64bit
4.11.0 multipage frame input discrimination
- multipage_frame.qxw
- (6.16 KiB) Downloaded 46 times
