Hi, I tried updating from 4.10.5b to 4.11.0 and noticed a change in the behavior of the click and go for an RGB fixture. The intensity for slider works fine but the color control slider does reliably update the DMX value. I have seen it work once or twice in testing but have not yet established a pattern. I experimented with the "monitor levels" mode but that did change what I was seeing with the control behavior.
I have confirmed this on Linux Mint x64 and Windows 10 x64. I am attaching a sample workspace with the the fixture definition files I'm using. The controls in question are in page 1 of the "LED Rows" control on the right side of the console.
Thanks,
Matt
Click and Go RGB Not updatiing DMX
- Real Name: Matt Weber
- Sample.zip
- (15.18 KiB) Downloaded 54 times
- Real Name: Lukas
Hey!
I'm sorry but I'm not able to reproduce this with your workspace on Xubuntu 14.04 64Bit. Are you able to reproduce this in a minimal workspace? Are you sure your problem is not simply HTP-related (when using LED color slider on page 2)?
Regards,
Regards,
Thanks for the reply.
I created a very simple workspace instead of pairing down my full workspace, I should have done this in the first place. I tried it in 4.11.0 and saw no change in the DMX monitor. I tried it with 4.10.5b and saw the DMX monitor reflect the changes to the rgb dmx values. I added 2 fixtures then attached level mode sliders for Intensity and RGB mode slider for color. I also added a similar pair for a fixture with a fixture definition bundled with QLC+ to see if there could be something odd in my fixture definitions.
I have used these definitions for a few years with no issue and see no issues with them in 4.10.5b so I really don't suspect the fixture definitions. I added the bundled fixture just to try every possibility.
Thanks,
Matt
Thanks,
Matt
- Minimal Sample.qxw
- (4.95 KiB) Downloaded 58 times
Great, thanks! I had seen this thread, I really do try to search before I create a new thread but since that thread mentioned several items and RGB was not one of them I wanted to metion it.
Thanks again, and thanks to all for the great work.
Matt
- Real Name: Lukas
Still I recommend you to try a test version in the software development section!mgweber wrote: ↑Mon Aug 07, 2017 5:56 pm siegmund wrote: ↑
Mon Aug 07, 2017 7:42 pm
Nevermind - this obviously was an issue. As Massimo said here this is fixed in the test versions and will be fixed as well in the next release.
Good news! I tested with the 4.1.11.60 windows build and the DMX monitor indicates the correct values while updating the colors. I won't be able to test with the DMX interface until later this week but stand alone operation looks good.
Thanks,
Matt
Thanks,
Matt
