The scenario:
VC with multipage frame, each page has several sliders. When switching pages, BCF does not get correct feedback, faders do not move.
QLC+ latest git, ubuntu.
4.10.5b is OK. I tried git bisect, but I got lost and didn't find anything. Tomorrow I have a gig, I tried to upgrade my odroid from 4.10.3 to git head
to make use of page shortcuts, but will have to revert to 4.10.5b tonight.
Maybe next week I will investigate more.
There might be related threads describing the same problem, I don't have a time to check them, maybe later.
This is mostly to let people know there is this problem.
https://github.com/janosvitok/qlcplus-w ... -lamac.qxw this workspace exhibits the problem
(big frame down left, the only one with pages enabled)
multipage frame does not move BCF2000 faders properly when switching pages
Issue confirmed and apparently it appeared around https://github.com/mcallegari/qlcplus/pull/937
Basically hidden widgets were sending feedbacks too.
Fixed on GIT now
Fixed on GIT now
That agrees with my observations - slider positions from one of the pages stuck on the controller regardless what page I moved to.
I will retest when I find some time.
Filip, please try the latest git if you can. It should be fixed now, though I hadn't verified the fix yet (if I recall correctly, Massimo has BCF or at least touch OSC, so he tried it for sure).
I tested with a BCF2000
Test builds updated (except for macOS)
