I found a bug regarding the speed dial widget. When tapping, the current multiplier value is ignored when it is >1.
Steps to reproduce:
- Go to VC, live mode
- Start the chaser with the button, you'll see the effects by the two buttons next to it
- Tap with multiplier = 1 -> Chaser continues on every tap (as expected)
- Tap with multiplier = 1/2 -> Chaser continues on every tap and in the middle between taps (as expected)
- Tap with multiplier = 2 -> Chaser continues on every tap (NOT as expected)
Regards,
