HELP : Event is coming..
Baer
Real Name: Matthias
I'm not sure if i got from the Video what you are doing, but remember that submaster also works only on the Values inside the same frame. Maybe you set the value somewhere else in your workspace
igorrobertifoc
Thank you Baer,
if, with a collection, outside the frame I set a scene inside the frame with the submaser? The submaster understand that is a scene inside the frame and modify the intensity?
Thank you very much
Baer
Real Name: Matthias
not sure about this
First guess would be that submaster has no influence if you activate the scene outside of its frame
But can't tell for sure.
igorrobertifoc
mmm :( I'm thinking a workaround with loop back. The result is that all scenes linked to the illuminance of par (or head) will be moltiplied with a factor (example 50%).
Do you have any idea how to do?
Thank you
igorrobertifoc
Hello, I tested. It dowsn't work, if you turn on a scene outside the frame the submaster is ignored :(
I think is because if you have 2 frame with one scene will work with 2 different submaster
viewtopic.php?t=6873
1.. I'm too late? :)
igorrobertifoc
No way. It's not possible :(
