when i use a color of one of my PARs in Audio Trigger it makes my Intensity fader inoperable.
I can use the dimmer intensity of any of the lights into the DMX Type and still control the RGB levels, but when I put any color form any of the lights into one of the frequency triggers it can no longer be controlled by the RGB faders.
for example, i have 3 faders where 1 controls R on all 4 PARs, one controls G on all 4, and one controls B on all. then a second fader controls Intensity of the dimmers on all 4 PARs. so if i put say PAR#2 on a frequency band, then when i move the B fader only 1,3,4 move, but not 2 — even if Audio Trigger is turned off.
it used to not do this and i could blend colors into the Audio Trigger to shift the effect color. for example, i used to be able to set blue to lower frequencies and red to higher and when i increased the B fader shifting the red to purple.
i tried using v 4.9, but it still didn't work. i know it used to, so i'm confused as to why not now.
(on Mac MBP El Capitan, DMXKing micro, 4.10.5a)
