Copy and Paste Cue Lists in Steps mode
mdmayfield
Real Name: Matt Mayfield
This post is to report an issue with copy/pasting a Cue List with its Side Faders set to Steps behavior. To reproduce:
1) Create some scenes and a chaser
2) Create a Cue List in the VC and assign the chaser to it
3) In the Cue List's Behavior tab, change from Crossfade to Steps and hit OK
4) Select the Cue List in the VC and click Copy
5) Click Paste
6) Open the Behavior properties of the newly-pasted Cue List
Actual result: new Cue List is set to Crossfade side faders behavior
Expected result: new Cue List is set to Steps side faders behavior
I finally got QLC+ to build from source :D and tested this on a Git clone from last night.
Hey,
I created a pull request to solve this issue, thanks for reporting!
janosvitok
Real Name: Jano Svitok
Merged. Thanks to both of you!
