Re: MIDI Feedback No Longer Sent from Disabled Frame
Posted: Tue Feb 14, 2017 4:13 pm
by siegmund
Thanks, I see now what happens - seems like a lucky catch
Anyway, thanks for the additional report, I wouldn't have noticed this otherwise.
Posted: Wed Oct 18, 2017 7:21 am
by electronicsfreak
Hi all!
New to QLC+ but am learning! Fun stuff.
I believe I'm having the same issue. When setting a button with midi feedback to enable/disable a frame, it looks like the enable frame feedback is sent, but disable frame feedback is not.
In operate mode:
Press button on controller, button illuminates on controller, frame is enabled in virtual console.
Press button on controller again, no change on the controller (button still illuminated), but the frame is disabled in virtual console.
I tried assigning different available buttons on the controller with feedback, but they all have the same result.
I am using an Akai APC40 as a controller and am running QLC+ version 4.11.0 on Windows 10
Any thoughts?
-EF
Posted: Sun Nov 26, 2017 7:46 pm
by bluescreen25
electronicsfreak wrote: ↑Wed Oct 18, 2017 7:21 am
Same problem with V4.11.1 .
Posted: Mon Nov 27, 2017 8:46 pm
Enable feedback fixed on GIT
Test versions on the way
Posted: Wed Nov 29, 2017 3:33 pm
by bluescreen25
mcallegari wrote: ↑Mon Nov 27, 2017 8:46 pm
This works. APC Feedback in case of enable/disable frame ok....but:
I put a cue list into frame. Chaser invinite timed steps. In Chaser RGB Matrix steps inside with own times.
The cue list is triggered by midi-beat in "next step" like in tutorial "Audio triggered cue list".
If i disable frame , the cue list freezes(paused) in last step working endless, but it should stop not pause ! (because the light are already on)
Enabling the frame the trigger starts steps from last step paused. I wish to switch with APC Buttons between some cue lists.
regards, Ralf
