Switching pages disables all widgets
Hey guys,
again noticed something weird while switching pages. Now after a page switch, every widget gets disabled.
The even weirder part is, that this only happens to a specific workspace. So as I was not able to reproduce it in a new workspace, here is my current one.
Just go to vc and switch pages and every widget gets disabled.
The issue was present in 4.10.5b as well as it is in the latest sources. 4.10.4 was fine.
Tested on Xubuntu 14.04 64Bit (Qt5).
workspace.qxw
(299.23 KiB) Downloaded 47 times
starwolf73
I second that. The version 4.10.5b seem to have issues with switching pages. If you have multi page widget and you switch the page and come back, most widget on those page except Slider and XY get disable or unfocus. I reinstall 4.10.5A and it work fine again.
Tested on Windows 7 64 bits.
Figured it out. It only happens to multipage frames that contain frames themselves.
page switch widgets disabled.qxw
(13.98 KiB) Downloaded 123 times
Hey Lukas, since this is the third issue report around the same problem, I decided to take a step back and revert the first change that caused all the recent issues.
Instead, I solved the original issue (viewtopic.php?f=33&t=10606) the way it should have been fixed since the beginning.
Please test the GIT code and see if you find any other issue. Thanks
Hey Massimo,
thank you for the new fix - at least every issue from the past weeks about the pages stuff seems to be resolved (no guarantee for other things tho :D )
Also thank you for your patience with my testing behavior, which seems to be pretty bad...
Still I really like to see things going in here!
No problem at all !
Instead, thank you for the accurate reports. They save me a lot of time when debugging.
PiotrNowik
Real Name: Piotr Nowik
I can confirm the same issue as siegmund reported in first post.
Windows 10 32bit computer with QLC+ 4.10.5b
Regards
Generic USB-DMX box(es)
Korg nanoKONTROL2
Windows 10
The issue has been fixed. Meanwhile, you can use a test version (not recommended for production use) or an older QLC+ version (4.10.4 should be fine).
PiotrNowik
I have to use both - 4.10.5b and 4.10.4 - depends on which laptop I've got at the moment ;)
Korg nanoKONTROL2
Windows 10
