Unable to edit widgets in a multipage frame
Hey guys,
I discovered a bug that must have been introduced very recently. It regards multipage frames in the virtual console. After a page switch it is no longer possible to edit widgets that are in the frame.
Steps to reproduce (have a look at the attached workspace):
  1. Turn around slider in the frame on page one (works as expected)
  2. Switch to page 2
  3. You are no longer able to move/edit the slider (not as expected)
Tested on Xubuntu 14.04 64Bit with the latest sources, but it is also present in QLC+ 4.10.5b.
Regards,
multipage bug.qxw
(3.07 KiB) Downloaded 57 times
Uhmm....this has to be a product of this other report:
viewtopic.php?f=33&t=10606
Funny thing is you are the one who wrote it, and tested also :)
Tomorrow I'll see what's going wrong.
This is the pardigm of the "too small blanket": you pull it to cover your shoulders and your feet remain uncovered ! lol
mcallegari wrote:Uhmm....this has to be a product of this other report:
Most probably yes - so sorry and shame on me that I didn't noticed that yet :( [I only said that the enabling issue is fixed, not that it hasn't introduced some other stuff btw :D :D ]
mcallegari wrote:This is the pardigm of the "too small blanket": you pull it to cover your shoulders and your feet remain uncovered ! lol
That reminds me of: "Just keep debugging your code, and you will finally fix it. It might not be today or tomorrow, but it will be soon."
https://s3.amazonaws.com/rails-camp-tut ... e-code.jpg
Alright, should be fixed now for good.
I tested also the original report of enabling/disabling a frame and switching page.
Seems to be working in all cases now.
Also works for me now. Thanks for fixing! :)
samatnyc
Real Name: Sammy
I don't know if this is a bug, but I can't seem to get widgets to stick to collapsing/collapsible/whatever frames, no matter which I put on front/back.
Is there a way to put a widget into a frame?
Sam
Michigan, USA
2012 MacBook Pro Retina, 2.6 GHz Intel Core i7, 8 GB RAM
OS X 10.12.3 beta
Enttech DMXUSB Pro
Primarily using w/Ableton Live 9.7 for use w/gigging cover band
Hey, this is not the topic of the thread - please avoid hijacking in the future.
Anyway, you simply need to select the frame and add a widget. Make sure the "accept child widgets" option is enabled in the frame's properties dialog.
