Cue List faders problem
maximortal
Real Name: Iro Suraci
Post by maximortal » Mon Dec 19, 2016 7:20 pm
Vers. 4.10.5.246
Virtual console bug
Faders of Cue list works incorrecly if linked
If you got 2 cue named A and B both with 2 generic dimmers
A: CH 1 @ FF / CH 2 @ 0
B CH 1 @ FF / CH 2 @ FF
If you put fader each to 50% the DMX monitor show this values:
CH 1 @ 51 %
CH 2 @ 51 %
expected behaviour is
CH 1 @ FF
CH 2 @ 50 %
I'm not sure but this bug there is also in previous versions
This bug is really important to been fixed for theatrical use of QLC+
Thank for you grat job
Cheers
janosvitok
Real Name: Jano Svitok
Re: Cue List faders problem
Post by janosvitok » Mon Dec 19, 2016 7:49 pm
Maximortal,
I've moved your topic to a better place.
Post by mcallegari » Sat Dec 24, 2016 11:57 am
Can you please post a sample workspace to reproduce the behaviour you're seeing ? Thanks.
By the way, the description you provided seems like the correct behaviour to me.
When linked, the side faders go in opposite directions, so it is correct that @ 50% they are both @ 50%
maximortal
Post by maximortal » Thu Dec 29, 2016 1:51 pm
yes, from a particulart poin of wiev you got right, this behaviuour is correct, but no if you lock the sliders each other. I mean that the expected behaviour is something like Spark consoles: connected faders become a linear crossfader between two scenes. In other words DMX values of scene A and scene B booth @ 50% must add each others.
to recreate bug remember to lock fades each other.
bug report.qxw
(2.8 KiB) Downloaded 22 times
Post by mcallegari » Thu Jan 05, 2017 7:17 pm
I think I've found a solution to this without impacting the code too much.
The code is in the "morphblend" branch on GitHub.
Otherwise, Windows build available here (4.10.6.54): https://dl.bintray.com/mcallegari/qlcplus/
Please test and let me know if it works and if it causes regressions somewhere else
Post by mcallegari » Sun Jan 08, 2017 11:58 am
@maximortal, can you please help with this by testing the development version ?
The issue resolution is now in progress and I'd appreciate to hear feedbacks from different users. Thanks
maximortal
Post by maximortal » Mon Jan 09, 2017 11:00 am
yes I can help if youneed it. What I have to do exactly?
plugz
Real Name: David
Post by plugz » Mon Jan 09, 2017 1:18 pm
You go here, you install the test version, you test it.
maximortal
Post by maximortal » Wed Jan 11, 2017 1:46 pm
tested on 4.10.6.54 and it has finally expected behaviour.. great!
now i'm investigating about another issue on chaser inside an another chaser.
i'll keep you udpated.
edogawa
Real Name: Edgar Aichinger
Post by edogawa » Wed Jan 11, 2017 7:39 pm
I just found this thread, and as it seemed to address the most severe long standing problem we theater guys have had with the cuelist crossfade, which has been discussed in several threads over the past 2-3 years (intensity dropping when moving both faders in parallel/linked mode), I immediately had to build from git and test it :)
Well, I currently don't have my conventional dimmers at home, and the two 24 channel DMX LED Controllers I ordered from AliExpress haven't arrived yet, so I cannot test with physical lights right now. But from watching the dmx monitor it indeed seems to work, yay!!!
Can't wait to test this in a realworld environment, this will save me a lot of time and hassle with directors in future productions. Many theater lighting techs prefer to perform manual in favour of timed crossfades, because the fade time often depends on what actors do on stage, which can vary in time a lot from one to another evening.
One question though, is it on purpose that this new code only works on linked faders? Each and every lighting desk with a two fader crossfade playback that i've had the chance to work with operates with this "crossfade law" while still being able to move each fader individually to separately control fade in/out ...
Cheers, Edgar
