Hi there, is this on purpose or a bug?
Talking about the 8 Cue lists on the bottom right, i use the frames to disable and enable them because i want to use one and the same keys to tap the duration, go to next previous cue, apply, start, stop, but i want to be able to select which of the 8 frames are modified. It does work for the faders and the Speed Dials
Cue List ignores that it is in a disabled Frame
- QLight_BadHomburg_ZoomR16_desk.qxw
- (136.97 KiB) Downloaded 82 times
The same seems to apply to enable disable buttons of child frames of a disabled frame
I'm using a Midi command for disable enable button of each cue in the setup and they should not be triggered when the lower left one is active but the Chasers&Sound to Light frame is disabled
